Can I use the NI 9403 to connect an SPI interface device?
Hello.
I am busy with my final year project and I need to be able to scan a barcode in order to determine what task the autonomous vehicle must execute.
I want to connect a barcode scanner to the NI 9403 module. I just want to know if it is possible and if so, how can I read the data from the barcode scanner (which is in Hexadecimal) through a pin. I am new to the LabView and I'm not familiar with al the functions. I am currently runnig LabView 8.5 on my computer.
If this is not possible which DAQ modules would you suggest. I have looked at the NI 9401 module but I am not sure if I have to buy a new NI module.
I want to use as few as possible external circuitry, that is why I want to connect it directly to the CompactRIO. The interface of the barcode scanner is a wedge keyboard (PS/2). I have already connected it to a pc to test the scanner and I can see that the barcode scanner works.
The reason why I say it is SPI is because the barcode scanner has a clock and data line. Thus it is synchronous. When I connect the barcode's data line and clock line to an oscilloscope I can see the make and break codes.
Is it possible to read the data coming from the barcode into an array when programming in the FPGA block diagram. I assume that the array type will be Boolean. Then I want to extract the different make codes to compare it with a database of ASCII codes. For example the barcode will say TASK0112.
The last four ASCII codes will be compared to a database and the appropriate task will be executed.
Can you please help me.
(3,447 Views)
Achillies,
Thanks for using the NI Forums! In the future, I would ask that you post your question only once as it gets confusing having multple threads.
Duplicate Thread Here
Ben Sisney
FlexRIO V&V Engineer
(3,423 Views)
