Calling DLL functions from LabVIEW Real-Time Module
I have LabVIEW Real-Time Module version 8.20 with PXI hardware. This uses Phar Lap ETS RTOS, and will support DLLs written in Microsoft Visual Studio 6.0 and Visual Studio .NET 2003. My question is if I upgrade to the current version of LabView Real-Time Module, can I use later versions of Visual Studio to write DLLs?
From searching the NI web site all I can find is that the version of ETS has changed.
Is it possible to use vxWorks on PXI hardware?
(6,768 Views)
Hi Paul,
If you still have a question on this I believe the answer is yes, they still will work. We actually have a tool just for checking this.
You won't, however, be able to use vxworks on the PXI.
Jesse Dennis
Engineer
INTP
(6,639 Views)
Hi Jesse,
Your reply sounds OK. Unfortunately the link to the tool doesn't work for me. Can I get to it through another route?
Paul Tyler
(6,625 Views)
Accepted by Paul_Tyler
Good morning Paul,
Lets try this again:
How Can I Verify that My DLL is Executable in LabVIEW Real-Time?
Jesse Dennis
Engineer
INTP
(6,620 Views)
