Can bias resistors for differential channels be soldered on the breadboard area of SCB-100 box
Dear enthusiasts,
Can the breadboard area of SCB-100 box be used for soldering bias resistors. If not, whats the best method for adding bias resistance.
(3,200 Views)
Yes, the breadboard of the SCB-100 can be used for soldering bias resistors. You could also just use the screw terminals and connect bias resistors between Analog Input(+) and AI Ground and Analog Input (-) and AI Ground (for differential inputs).
(3,200 Views)
