Can't get cRIO 9035 to work
It does turn on, and comes up under "network settings" in MAX with USB. It also pops up "New device detected" from LabView with USB. However, it does not show up under "remote devices" in MAX, neither with USB or with ethernet cable. It works on other computers - what can I do?
If any more details are needed, please let me know.
Thanks!
(3,372 Views)
Hi jboganes2,
Have you made sure you're following the exact steps covered in:
Connecting the cRIO-9035 to the Host Computer or Network Using Ethernet
Also check you have the correct software and drivers installed: NI-RIO Device Drivers February 2015 to Current, and LV RT, FPGA 2014 SP1 to Current
If niether of these work I'd suggest using the RESET button to troubleshoot network connectivity. Hold the RESET button for 5 second, release and repeat to boot the controller into safe mode, enable Console Out, and reset network adapters to default settings.
Let us know how it goes.
Rebecca
(3,344 Views)
Accepted by ikmjb
I tried everything - it just would not connect automatically.
However, I did fix it by manually adding everything - booting the cRIO with the mini-DP cable, typing "ip addr show" in the unix terminal, and adding the cRIO9035 to MAX with that same IP. This worked. In LabView I also had to add all of the modules manually. Quite easy if you know what modules you are working with, but a hassle indeed.
(3,339 Views)
