Can tdms streaming vi's be used in LabVIEW Realtime?
Hey Steve,
Sorry for getting back to you late as I've been working on several other projects.  I looked to see if I could find one of my implementations using interrupts but I have misplaced it on my PC.  I'll see if I can locate it over the next couple of days to show how I've implemented this in LabVIEW FPGA and LabVIEW Real-Time.
However, I did find an implementation of Polling and Scheduling I really like that I'll post so you don't go home empty handed tonight 🙂
Basset Hound
Message Edited by Bassett Hound on 04-15-2008 05:45 PM
Message 21 of 25
(3,483 Views)
Basset,
Sorry it took me so long to get to it.... but I tried out your Polling and Scheduling DMA example and it really works well.  It seems to address several of the issues I have always had trouble with (lots of CPU usage and DMA timeouts)....Thanks.  I was wondering however, if you did find your example that uses interrupts.  This polling and scheduling example is great, but it does not seem to be the best example to put in a control loop were you need rather steady loop times.
Steve
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 22 of 25
(3,434 Views)
Hi SteveA,
I was reading your post and I found this example from NI Developer Zone that uses interrupts with DMA data transfers. I hope this helps!
Carla
Message 23 of 25
(3,414 Views)
Hey Steve,
Sorry I"ve been absent on the forums for the last week or so.  I did find my final versions of code I was playing with for different methods of pulling Continous DMA data on a Host cRIO ( including several others that work well in some applications).  I attached the code below.  Let me know if you have feedback on what worked well for you on your application.
Basset Hound
Message Edited by Bassett Hound on 05-01-2008 04:49 PM
Message 24 of 25
(3,405 Views)
Bassett.... Thanks I'll give this a try!!
steve
SteveA
CLD
FPGA/RT/PDA/TP/DSC
Message 25 of 25
(3,381 Views)
