Cluster Shared variables
I forgot to mention that the variable configuration categories you are missing are included in the LabVIEW DSC module.
Message 11 of 16
(2,992 Views)
Hi Gerardo, Actually I also expected the same and tried by removing the DAQmx control. But the result was same.Were you able to create a shared variable with my control? Thanks Kallis
BR
Message 12 of 16
(2,993 Views)
Kallis, Only when I removed the DAQ Task control from the main cluster. Kind of like the one attached.
Gerardo
Message 13 of 16
(2,984 Views)
Oops... I missed the hidden DAQmx Task control in my cluster. Till now I was thinkin it was the DAQms Phy. channel control...Thanks Gerardo, after removing that, I'm able to add it as a shared variable.
Kallis
BR
Message 14 of 16
(2,976 Views)
I meet this problem when try to use the cluster as a share variable.
First I create a cluster and convert it into type def. After that I create the shared variable. But when I add it to the program. It meet this error. I don't understand why.
Anyone has any idea
Message 15 of 16
(2,561 Views)
Try to remove the buffer on the shared variables.
Message 16 of 16
(2,433 Views)
