Communication protocol CRIO & I/O module
1. CRIO chasis connect other daughter module with 9 pin connectot( DB9 connector, I guess).
2. What is the protocol they follow. Uart(9 pin), MODBUS, SPI or other
(4,493 Views)
The C Series cards actually use a 15 pin connector (just like your VGA connector).
As far as I can tell, there are a combination of straight DIO and SPI interface for the communications.
None of this matters unless you are developing your own module.
(4,472 Views)
