 jtc
			jtc
			08-09-2006 02:53 AM
		08-10-2006
		02:13 PM
 - last edited on
		03-12-2025
		10:00 AM
 by
		 Content Cleaner
			Content Cleaner
08-12-2006 04:07 AM
08-14-2006 09:16 AM
Bong hello.
The cRIO application will continue running on the cRIO controller. The TPC 2006 will give you a user interface so you can control inputs and receive feedback. You will program a TPC 2006 appication and this will communicate back and forth with the application running on the cRIO controller.
In order to program cRIO, you have to use LabVIEW FPGA. If this is the software you used to configure your DIO for the cRIO, then everything should map correctly if you move the program from one place to another. However, if you programmed FieldPoint, then there is no mapping whatsoever. FieldPoint and cRIO use completely different drivers.
One thing to note is that the cRIO/FieldPoint application will continue to run on their respective controllers while the TPC 2006 will run the user interface application. In LabVIEW 8.0, you will have to use TCP to communicate back and forth with your application. However, with the new LabVIEW 8.20, you are able to use shared variables. It makes life so much easier.
Efosa O.
NIAE
