Compact RIO time reset after power loss
We something strange in the way the absolute time responds on a cRIO target.
When powering up the cRIO the timestamp seems to be malformed resulting in date/time strings like  "19013672-80u04m00s" (could be a bug in scan to string with option %<>T).
Nevertheless the originating stamp is not in the range "1904 - now", this doesn't happen with a soft reboot.
How is the cRIO absolute time handled?
Is a set absolute timeable to survive a short or long power cycle?
André (CLA, CLED)
(3,864 Views)
Hi André,
What cRIO controller do you have? And what software version?
Maybe this KB helps.
Bas
(3,772 Views)
Thanks for the response.
Our systems use the 9014 controller, not the ones indicated in the KB article.
André (CLA, CLED)
(3,769 Views)
Hi André,
Do you have your code? I can't reproduce it here. I also have a 9014.
I tried it with the RT set Date and Time vi. And with a format date time string.
And what time format string do you use?
Bas
(3,677 Views)
