memory usge of exe in RT
hai guys,
would like to ask if there is any way we can check the process memory usage of the *.exe  in cFP. As i use the built in function Tool>>real time>>system manager it only shows the RAM memory usage. I would like to check if the process is accumulating memory usage in RT.
Can i assume no memory leakage if there is no increase of used memory in the system manager???
thanks
regards
shamaran
(3,142 Views)
Yes, your assumption is correct.
(3,128 Views)
