Compact rio/NI remote IO connection with Ethernet Hub
I have a compact rio 9075 and I would like to do data acquisition thanks to the NI remote I/O module, but my compact rio does not have enough Ethernet port.
Is it possible to use an Ethernet Hub ? Furthermore, remote I/O communicate with the  EtherCAT technology.
Thank you.
(2,711 Views)
Accepted by MDVG
I am afraid that it is impossible to use an ethernet Hub to accomplish EtherCAT technology. NI EtherCAT only supports the target with 2 ethernet port.
Thanks!
(2,687 Views)
Ok, thank you for your answer
(2,620 Views)
