Compact rio reformatting after reboot
I have a strange problem with my real time code using a 9104 backplane.  Everytime I deploy the code and then manually reboot using the reset button or the reboot function, the compact rio device formats itself back the default IP and removes all its software.
I have tried two controllers (9014 and 9012) with the same results.  Is there anything with my code that would cause this to happen?
I am logging 40 channels to tdms files on a USB stick.
(3,320 Views)
Hi craigv2,
May be a simple question, but the front of the RT controllers have an IP Reset button that if turned to on will reset the IP address.
Basset Hound
(3,315 Views)
