Compilation FPGA Labview2013
I am using a compactRIO 9114 with the Labview 2013 and Xilinx 14.4, and I´m having problems with the compilation.
When I compile my complete subvi I got the error "Synthesize - XST" failed (I attached the report), but if compile only part of the subvi, the compilation is succesfull.
I was already compiling the FPGA subvi in Labview 2012 and it was working without any problem.
Also in the report I have realized that the license is not active, but I included when I installed the Xilinx Tooling...
Could you please help me with this??
Thanks and best regards.
(5,704 Views)
Are you writing to a memory location within your VI? There might be a problem with the way its configured...
ERROR:HDLCompiler:410 - "C:\NIFPGA\jobs\aM7Cacr_PQA65GW\FPGAwMemoryn0.vhd" Line 100: Expression has 11 elements ; expected 10
Netlist FPGAwMemoryn0(20,1,13,9,600,8,0,0)(rtl) remains a blackbox, due to errors in its contents
I would try using a disable diagram structure and use it to disable the memory write call and try to compile to make sure... if you can post a screenshot of the VI you are compiling that might be helpful.
(5,671 Views)
Besides, you can try to redrop your Memory Write Node and compile again, just to make sure whether this happens to a new created VI in 2013.
(5,658 Views)
