12-05-2013 01:05 PM
12-10-2013 03:30 PM
Are you writing to a memory location within your VI? There might be a problem with the way its configured...
ERROR:HDLCompiler:410 - "C:\NIFPGA\jobs\aM7Cacr_PQA65GW\FPGAwMemoryn0.vhd" Line 100: Expression has 11 elements ; expected 10 Netlist FPGAwMemoryn0(20,1,13,9,600,8,0,0)(rtl) remains a blackbox, due to errors in its contents
I would try using a disable diagram structure and use it to disable the memory write call and try to compile to make sure... if you can post a screenshot of the VI you are compiling that might be helpful.
12-10-2013 10:08 PM
Besides, you can try to redrop your Memory Write Node and compile again, just to make sure whether this happens to a new created VI in 2013.
