Connecting cRIO 9054 with arduino (Ethernet Shield) and communicate over UDP protocol
Hello guys,
I have a weird idea that i want to realize. I have a cRIO 9054 and i would like to generate pwm signals to control several motors. I am on a low budget and i can not purchase c-series modules to achieve it, therefore, i am trying to find a way around. By the way i tried several software-based pwm VIs with NI 9375 DIO module (which is not able to access counters within cRIO), however the ESC doesn't seem to recognize or "like" the signal that i sent. I can not see the signal that i am sending since i don't have any oscilloscope. So, basically what i want to achieve is to sent data over UDP to Arduino and map this data to pwm for ESCs. Are there anyone who tried this kind of setup before. Thanks!
(1,184 Views)
Hi onur_ers
There is a video where you can understand the concept how to implement your code to achieve your desired result.
Also, I suggest you contact with Arduino support as well, they might have some examples to help you implement your code.
Regards)
________
Best way to thank is giving Kudos / Marking as a solution.
(1,018 Views)
