Connecting the NI 9213 thermocouple module and a cRIO chassis with a DB cable
My goal is perform ''remote'' acquisition of temperatures, using an NI 9213 thermocouple module with an NI 9075 CompactRio chassis. To implement this ''remote'' sensing task, I wanted to use a 15-pin D-Sub cable to connect the thermocouple module to the cRIO chassis, and therefore avoid the direct D-Sub connection between the two. I tried this with a 25 feet DB15 male/female cable (VGA), but it doesn't work (no temperature reading on my LabVIEW), as opposed to when I directly place the NI 9213 module in the chassis. Is this supposed to work, or is it necessary to use a ''standard'' NI cable to succeed in connecting the module and the cRIO?
Thank you.
Marianne
(2,615 Views)
Accepted by MDVG
No, it's not supported as this article indicates.
(2,581 Views)
ok. Thank you for your answer.
(2,557 Views)
