Crio 9014, collecting analog and GPS data
I am using CRio 9014 and have a program up and running to collect data from 15 analog channels. I want to add GPS NMEA string GGA. I may use the GPS lat/lon and time to synchronise the data. Can some one help me with initial startup?
I will appreciate,
Ajay
(4,551 Views)
Hi Ajay,
 Do you have a particular device which you can communicate to that has a GPS on it or are you thinking about searching a particular address on a site like google earth to poll the information? I have found this forum that describes the latter method if you are interested.
Andrew
Message Edited by Andrew_E on 06-30-2009 11:26 AM
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(4,531 Views)
Hi Andrew,
I will be using a standard Trimble GPS wired and configured to send GGA string.
I would appreciate more leads on this.
Ajay
(4,527 Views)
Hi Andrew,
Just to give few more insight, I have a FPGA reading the analog data and sending to the host machine and there I am writing all the stuff. I need the GGA string from a GPS source to be in the same textfile having lat, lon and GPS time.
Please suggest,
Ajay
(4,526 Views)
If you want to synchronise analog data with GPS, the best way is to use a digital module (9401) to make 1 or 2 RS232 to get the data from the GPS.
By using the PPS (on the digital module), you will be able to grab the analog data between 2 pulses then decode the GPS data ( time + position) on the RT
On the FPGA:
DMA FIFO1 will be for analog data
DMA FIFO2 will bbe for RS232
-Make one or two RS232 ( ode avalaible on the ni.com)
-Make a loop which change a FLAG (or using occurence) each time you have a PPS.
-Enable IRQ each time PPS has been detected.
-Find a way to know exactly how many analog data you have acquired since last pulse
!!!: Find a way to wait for the PPS before starting to write Analog data in the DMA FIFO
on the RT
Make a loop which wait for the IRQ
Read in the FIFO1 data > download only number of analog data you have per second
Read RS232 data form FIFO2 > decode  GPS data > decode the GPS time of previous PPS then of the analog data
You will have 1 seconde of analog data + GPS data of the same seconde
By this way, you don't really care of RT clock.
You will have a stable clock without drift a data with GPS timestamp
Mathieu
(4,513 Views)
Hi Mathieu,
I'm putting a system in place, rather on a short and rushed time frame, to gather 6 analog channels of data that need to be sync'd to GPS & PPS signals. Hoping to use cRIO as it needs to be rugged & small.
Any suggestions to not repeat past mistakes you have learned from? Suggestions are appreciated!
(3,598 Views)
