crio
I have to generate and store the jpg file in crio. The code works on my local PC. When I deploying the same in crio, it didn't work. It returns zero. Also I tried the paths like c:\test.jpg or /c/test.jpg; both didn't work. We are using Labview 2011 full professional development system.
cRIO 9025
Chasis 9113
NI 9229
Thanks for the help.
ASAP.
Ashokan
Ocean Acoustics,
National Institute of Ocean Technology,
Chennai, India - 600100.
(4,258 Views)
Hi Ashokan,
What do you mean by "it returns zero"?
Are you sure the functions you're using are available on the RTOS?
I would try first to "just" write a .txt files to distinguish if the error you encounter is path-related or jpg-related.
Have a good day,
Flo
(4,246 Views)
I rectified the error. Since cRIO didn't support strings to path vi, jpeg vi and png vi. It supports only bmp vi.
The file size of the bmp vi larger than of jpeg vi.
Also cRIO didn't support for zip file vi's.
What I have to do? Any alternatives....
Thanks & Regards,
Ashokan. M
Ocean Acoustics,
(4,242 Views)
