Datalight Reliance v2.10.1053
I am using a cRIO-9082.  It's been working fine for a few days running various file I/O and I/O operations.  We did a power cycle and then on startup it gave the following error to the console (VGA) monitor
Transferring control to user program
Copyright (c) 2003-2006 Datalight Inc.
Reliance v2.10 Build 1053: Assertion failure in module rlinode.c line 1138 (DCL=351)
I tried the various dip switches and can go into the BIOS but none get me past this.  Any ideas?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 1 of 9
(7,215 Views)
Hi Terry_ALE,
I think a reformat would be a good step to try out.  This Knowledge Base article should be beneficial:
http://digital.ni.com/public.nsf/allkb/DD1B72485DA949158625784F005DCEF6
Joel I.
Message 2 of 9
(7,188 Views)
Hi Joel,
Thanks for the link.  I am working on this with NI Support but thought it would be good to get this posted in case others encounter this (Google searches didn't have anything on this particular error.
We will reformat the device using the instructions on the link.  We will however send it back for a replacement because at this point we are not sure if it is specific to our device.
Anything else you come across will be very helpful.
ALE Consultants
Message 3 of 9
(7,183 Views)
Hi Terry_ALE,
The instructions should still be valid for a cRIO-9082.
I think a reformat is a good first step in resolving this issue.
Let me know how it goes!
Joel I.
Message 4 of 9
(7,166 Views)
I followed the procedure and got the same boot error with the following attached to the end:
System error KERNEL.446580: Illegal Win32/ETS API from ISR priority
ALE Consultants
Message 5 of 9
(7,139 Views)
Hi Terry_ALE,
I think it may be time to RMA this device  You mentioned you were working with NI Support, so work with them to process an RMA for this device.
Joel I.
Message 6 of 9
(7,132 Views)
We are RMA'ing the device.  Thanks for your help!
ALE Consultants
Message 7 of 9
(7,128 Views)
Hello, i have the same problem in my cRIO-9082.
@Terry_ALE did you were able to solve it?
thanks!
Message 8 of 9
(6,802 Views)
We RMA'd the device and NI said the SSD had to be replaced.  Nothing regarding why this happened.
ALE Consultants
Message 9 of 9
(6,797 Views)
