Delay time of NI-9227 C module
In the manual of the 9227 module from 2010 it is stated a delay time of 38.4/fs+3.2us, on the knowledgeBase article here  (Why Is My Data Delayed When Using DSA Devices?) it is 40/fs+3.2us. Which one is the correct one??
(5,635 Views)
Hi AndyKr,
did you find the answer ?
(2,411 Views)
Hey Charlie,
I'll be surprised if you get a reply on a 7 year old thread, but I'm adding this as a note.
The manual is almost always correct as they are created once and then left, whereas Knowledgebase articles are updated as more information is found that is relevant.
A good example is the article that Andy linked, it was last updated only 2 months ago and no longer references the module that this question relates to. As such, the value from the datasheet should be treated as correct.
Hope this helps!
Mitch
(2,399 Views)
Beware of NI-9227 Datasheet !!!
(last version is dated July 2014).
Why NI used such a stange notation to say "Input delay = 40.01/fs + 2.9 µs"  ?
The result is a factor 100 error if you understand the formula as 40 * 5/512 instead of 40 + 5/512.
There is a hudge difference !
Exemple
if fs=2 kHz, you may think that the input delay will be 0.19 ms. In reallity you will observed an input delay of 20.0 ms !
If you have synchronisation considerations in your application, you should be very carefull with this subject.
Hopping that this datasheet will soon be corrected...
I will checked this point personaly.
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
(1,580 Views)
