Incorrect Remote File Browser File Modification Time
I have always noticed a +8 hour offset between the system time of my cRIO-9035 controller and the modification time reported when browsing files using the web remote file browser. All time function on the controller report the correct system time so this appear to affect only the remote file browser. Wondering if it's normal behavior to report the file modification time in GMT? If so, why?
System time.System time.Modified time is +8 hours ahead.Modified time is +8 hours ahead.
(1,312 Views)
Hello Ricky77,
This problem can occur if the time of your cRIO controller has been set incorrectly.
The Current Time is Incorrect on My LabVIEW Real-Time Controller - NI
You can try setting the time of the cRIO controller from LabVIEW.
Set RT System Time to Windows PC Time Down to Milliseconds - NI
These articles might help you to solve the issue
KUDOS are the best way to say thank you 🙂
(1,282 Views)
Thanks for the response. Sorry if I wasn't clear, but my cRIO time is set correctly to my time zone (as is shown in the first picture). All time function return the correct time in LabVIEW as well. The only issue is that the modified time of the files shown via the web based Remote File Browser shows the time as 8 hours ahead of what the cRIO time is. It seems the file modification timestamps are in GMT, but I don't know why?
(1,273 Views)
