Deploy Error; "Labview: Resource Not Found"
I am trying to deploy an RT application to a PXI embedded controller. Sometimes, I get an error message in the Deployment Status window that says "Labview: Resource Not Found". How do I eliminate this error message?
I have attached a screen shot of this issue.
 -Somit
(3,098 Views)
Hi Somit,
Thanks for posting. You mention this error message only displays some of the time. Does this happen with ALL Real-Time applications you attempt to deploy or a single application?
Also, can you more specifically explain "sometimes?" Is it every first run? Every other run? Is there any pattern to receiving the error message?
Finally, it appears there is more to that error message (NI-Scope related). Can you please include all texts shown in that error window?
Cheers.
Message Edited by Riconquistiamola on 08-16-2007 10:29 AM
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(3,087 Views)
