Different loop times
I have a timed loop with 500ms loop time for Counters and Analog Buffered reads. The control loop has a 20ms loop time. Is it possible to read from the buffer, using DAQmx Read in these two loops, without altering the current read position in the buffer?
Is there a way to configure the DAQmx task(s) simiar to the "DAQ Occurrence VI"?
Regards
Roger Isaksson, Damill AB
(3,734 Views)
Hello Roger!
I believe this question is under control now after the last e-mail conversation we had!
Good luck with your project!
Jimmie A.
Applications Engineer, National Instruments
Jimmie Adolph
Systems Engineering Manager, National Instruments Northern European Region
(3,705 Views)
Jimmie thanks for the support,
Sometimes it's good to solve some issues on your own as well, don't you think so? 🙂
Here is the code which I beleive should do concurrent reads, anyone should feel free to correct me if the semantics are in error!
(3,692 Views)
