How do I communicate with FPGA code in Flash Memory?
I have developed a control solution for an FPGA application that I would now like to use on several PXI machines, however not all of these machines have the LabVIEW FPGA module installed. I would like to download the FPGA application to the Flash memory of 3 or 4 PXI-7831R cards using our 'FPGA Development Machine'. I believe these cards can then be moved to other PXI chassis' and employed without the need to install other copies of the FPGA module.
How can a PXI with LabVIEW (7.0 or 7.1) and NI-RIO (1.3) installed communicate with an application running on an FPGA card (loaded from Flash memory)?
I don't seem to be able to give RIO visibility of the Controls and Indicators implemented in the FPGA code.
Paul
BTW: I have already posted this question on the LabVIEW Embedded board but I think that was the wrong forum for this type of question.  Apologies to anyone traumatised by incorrect postings.
(3,357 Views)
Hi Paul,
Once you have downloaded the personality to the FPGA board, you should be able to use the board in other PXI systems if you create a LabVIEW executable with the LabVIEW Application builder.
This should copy all files you need, so any PXI machines with the LV 7.1 run-time engine can communicate with the FPGA board
Kindest Regards
JamesC
(3,336 Views)
