Does the new Pentium-M controller support RT?
Does anyone know when RT will be supported on the new Pentium-M PXI controller? I am running IMAQ applications on older PXI RT controllers (PXI-8176RT) but I'm trying to increase the test throuput by switching to faster controllers.
(3,536 Views)
Hi mhig,
The release date of new Pentium-M PXI controller to be supported by RT is still not confirmed. However, R&D is working on it to be released. I have asked the R&D, so I might be able to tell you the approximate month of the release. I will post up another messege once I get any reply from the R&D.
Also you have mentioned about increasing the test througput and yes new Pentium-M controller will have higher spec.; however, that will depend where is your bottleneck is. You might have heard about PCIe-1429. If the bottleneck would be the transfer rate from the camera to the computer, then PCIe-1429 could also be your solution. Yet since it uses PCI express bus, there are no board for the PXI.
PCIe-1429 Camera Link Frame Grabber board
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14518
I will try to post up as soon as I get any new information.
Masatetsu Wake
NIJ AE
(3,490 Views)
Hi mhig,
Sorry for the delay, yet I was informed that new Pentium-M controllers with LabVIEW Real-Time is released today, June 1st. You could check the website below.
NI PXI-8196 RT
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201868
NI PXI-8195 RT
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201869
Masatetsu Wake
NIJ AE
(3,484 Views)
