"Chassis Temperature" in Analog Input Module for FPGA (cRIO-9201)
I have just gotten my cRIO with a analog module (9201) and a digital output module (9472).
When I place an Analog Input Module on my block diagram and double click it, I can choose from the following inputs:
Channel 0 through Channel 7
AND
Chassis Temperature
I have tried to find any documentation for this "Chassis Temperature" but so far without success.
If I read this input and feed it straight to an indicator, I get values in the range of 120 to 150.. Now, without more information, this number is rather useless. Does anyone know how to transfer this data to a temperature (either in the Celcius scale or the Fahrenheit scale)?
Thank you!
Project Engineer
LabVIEW 2009
Run LabVIEW on WinXP and Vista system.
Used LabVIEW since May 2005
Certifications: CLD and CPI certified
Currently employed.
(3,720 Views)
I still did not find any documentation for this "feature" but I lucked out and found the following:
in the folder: \labview 7.1\examples\FPGA\CompactRIO\cRIO-910x\
you should have a file called:
cRIO-910x support files.llb
in this there is a convert to temperature vi.
To get the raw data as a temperature, it looks like all you have to do is divide the binary data by 4 and the answer will be in Celcius.
Project Engineer
LabVIEW 2009
Currently employed.
(3,716 Views)
