Encrypt file-system of cRio
cybersecurity requirements are asking for encryption of file-system on our cRios (9054, 9068, etc). I wonder if there is something officially supported. In
Best Practices for Security on RIO Systems - part 1 , part 2  and part 3 there are many suggestions, but I haven't found anything about encrypting files and folders.
Any recommendation? Thanks in advance
(2,007 Views)
Accepted by mpignati
the way to go on Linux is usually to encrypt a partition with LUKS. But I don't think that it's possible to encrypt the whole NI Linux RT system with LUKS because this would need very deep changes on the OS. Though, encryption of a new created partition or an attached USB drive should be possible.
(1,988 Views)
Thanks for the answer. We do not need encryption of the whole NI Linux RT, just some folders. We are going to try LUKS then.
(1,969 Views)
Did it worked after all?
(1,115 Views)
Eventually we did not try it out. I believe it would work though
(1,075 Views)
