Erase or Format Primary disk of IC-3120 using System Configuration block in RT LabVIEW
I initially started with the Resource Monitoring VI for RT Target from find examples. It works perfectly when i deployed it on the IC-3120 for resource monitoring. But as I add the block of Format.VI from sys configuration, in order to format the drive. It gives the following error. The target is selected as localhost as you can see in the screenshots attached below.
nisyscfg.lvlib: Format 5.3 vi: 2890001<APPEND>
<b> complete callchain:</b>
              nisyscfg.lvlib.....................
Message 1 of 1
(1,005 Views)
