Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi...RTBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
just tried to build an RT app for download to a RIO-9073 chassis and got the following error...Any ideas??
Drew
An error occurred while saving the following file:
C:\Program Files\National Instruments\LabVIEW 2009\vi.lib\rvi\ClientSDK\Core\ModuleGeneration\CommunicationInterfaceUtility\niFpgaDmaChannelImplementation.ctl
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_RTEXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_CreateNewWizard_Invoke_CORE.vi->RTBUIP_CreateNewWizard_Invoke.vi->RTBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
Error 6 occurred at AB_Source_VI.lvclass:Close_Reference.vi -> AB_Build.lvclass:Copy_Files.vi -> AB_Application.lvclass:Copy_Files.vi -> AB_RTEXE.lvclass:Copy_Files.vi -> AB_Build.lvclass:Build.vi -> AB_Application.lvclass:Build.vi -> AB_RTEXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_CreateNewWizard_Invoke_CORE.vi -> RTBUIP_CreateNewWizard_Invoke.vi -> RTBUIP_CreateNewWizard_Invoke.vi.ProxyCaller
(7,816 Views)
Accepted by Drew.Rankin
NVM. Found the answer on the knowledge base...The folder name is too long.
(7,815 Views)
This happend once to me because the "build specification name" at Build exe windpw was too long, try to change the name of your exe file.
(7,145 Views)
Just confirming LV 2020 in Win10 - that this still is an issue...By default LabVIEW 2020 create a default RT path is this too long..[see image] I changed the temp Win RT build directory to a simple Documents\LV Builds
...and it works...
(2,150 Views)
