Error message - Failed to create directory for auto recovery VIs.
When I start up LabView 8. 2 on Linux, I get a dialog box with the error 'Failed to create directory for auto-recovery VIs.'
I click on it and it goes away no problem.
However, if I try to use '-launch' to run a VI from the command line, the message pops up and the VI will not run until this is clicked.
I looked in the .labviewrc file, and it was not clear which resource to use to set the directory.
Could you let me know how to set up a directory path for the auto-recovery VIs.
Mike Dixon
(4,338 Views)
Mike:
Before we get too far into the issue, what distribution of Linux do you have?
Rudi N.
(4,332 Views)
Hi Rudi
We are running Red Hat Enterprise 4.
Mike
(4,331 Views)
Mike:
Thank you very much for getting back with me. I wanted to make sure that your Linux was compatible and it is indeed compatible. I think that the issue may be with file permissions as mentioned in this post. Could it be that you are attempting to launch LabVIEW from a non-root login?
Please let me know what you find.
Rudi N.
(4,312 Views)
