Evaluate System for RT 8.6/8.5.1 - issues when using RT Desktop PC Utility Disk Drive
I am in the process of evaluating a PC system for use with Labview RT OS.
Initially, I used RT 8.5.1 (from MAX) to create an RT Desktop PC Utility Disk Drive, but our NIC is not supported and RT 8.5.1 does not support the White List feature. When presented with the menu after reboot, I select "7. Evaluate System" and run it which returns the issue with the NIC as expected. It also returns an error with regards to the SATA hard drive which is configured as AHCI.
Subsequently, I installed an evaluation version of RT 8.6 and Labview 8.6 to generate an RT Desktop PC Utility Disk Drive, but now, upon reboot and being presented by the same menu and selecting option 7, nothing happens. The computer simply hangs. I thought it may have something to do with other dependencies, so I installed everything on the Developer System, but this made no difference.
Am I missing anything? The PC is a Dell Precision T7400. I have two SATA drives (could this be the issue) which operates through some SAS controller (could this be the issue).
Any feedback would be appreciated.
Message 1 of 1
(3,480 Views)
