FPGA Compilation Error 61330 on a cRIO
Hello all,
Currently, I have to rebuild a fpga bitfile to account for a new hardware configuration on a cRIO. I installed the appropriate tools on my computer, which were able to compile the bitfile several times; but now I am getting an error when I compile. I have attached two images of the error to this message. I am currently running this software configuration:
Windows 7 with 8 gigs of RAM
Labview 2013 SP1
FPGA module
cRIO 13.0 drivers
Real Time module
Xilinx 14.4 tools
cRIO hardware: 9024 and 9022 w/ 9113 chassis
R Series Card 9401 and Quanser's Q1 card
*The Quanser card now takes up slot 1 in the cRIO and the 9401 card takes up slot 4. The 9401 card used to be in slot 1.
The compile problem started after I updated. I did have to cancel the update and restart it because I needed to use LabVIEW briefly. I have tried several things to help isolate the problem, but the problem still persists. I have disabled my firewall. Reinstalled the Xilinx tools. Completely updated my version of LabVIEW.
I found several similar posts (links to which are posted below), but none of those solutions did not help.
Has anyone else seen this problem before?
Thanks.
(6,769 Views)
Access Denied sounds like a read-only flag is set on the file or folder.
(6,767 Views)
That was one of my solutions. I have read write access to that folder. To test this I just copied and pasted a file in there. I've also made changes to files in the folder. When I say folder, I mean the folder that the compilation is going to send the bitfile to in the end. The VIs involved are password protected, but I have since removed the password protection, and the error is still occuring.
(6,760 Views)
Also check the NIFPGA folder. That is where the files are actually created. On my machine it is on the root of c:\
(6,753 Views)
Accepted by Savage_Aggie01
It turns out that it was a firewall problem. I had turned off my firewall, but there must have been a tertiary process still running. I added some exceptions to my firewall, which should have allowed the program to work, but it didn't. Once I deleted those exceptions the compiler ran with no error again. I think it's time to get a new firewall program. Thanks for all of your help.
(6,689 Views)
