FPGA Compile Server Error
Hello!
I tried to compile a FPGA VI with LV8.5 and the compile server stopped with this error message:
Mapping design into LUTs...
ERROR:MapLib:661 - LUT2 symbol
   "mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/BU2/U0/gen_structure_logic.gen_n
   onpipelined.a_lt_ge_gt_le_b.i_gen_carry_chain_comp/sel_0_mux00001" (output
   signal=mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/BU2/U0/gen_structure_logic
   .gen_nonpipelined.a_lt_ge_gt_le_b.i_gen_carry_chain_comp/sel<0>) has input
   signal "mytop/n_3491/n_3486/n_3475/n_3467/HiCompare/b<15>" which will be
   trimmed. See the trim report for details about why the input signal will
   become undriven.
I developed the VI with LV8.2 and could compile it without any errors. The VI contains a DMA-FIFO and several analog IO operations.
Can anyone tell me which part of the VI may cause that error?
Kind regards,
Christopher Zaum
(5,136 Views)
Hello!
Do you have Windows german?
Ty to set the regional settings in english and compile again:
http://digital.ni.com/public.nsf/allkb/A45687D827A81D6E86257195007807B3?OpenDocument
You can also try mass compiling your project to 8.5
Best regards
Ken
(5,060 Views)
Thank you for this hint! I use a german windows xp with sp2.
I will try to compile the VI again with English language settings.
Best regards
Christopher
(4,928 Views)
I recompiled the VI with english regional settings (us + uk) and it aborted with the same error.
As mentioned in the link above, I also switched off all other programms running in the background.
But the error still remains.
Could the problem be solved when I use Vista instead of XP?
Best regards
Christopher
(4,867 Views)
