lvlib that inclucdes Network-published shared variables cannot deploy!
 Good morning:
     I'm doing a project by using CompactRIO.  Since there are two cRIOs in the LAN,  I fall across a puzzel: if a project has the lvlib that contains network-published shared variables,it won't compile successfully.In the compiling report,it writes"the specified lvlib deployment failed(error:-2147467259).
     Moreover, a project which is created by the Real-time project wizard cannot deploy,returning the same error.It should be noted that the project runs smoothly when there was only one cRIO.
     What's the matter?Looking forward for your early reply.Thanks a lot!
Message 1 of 1
(3,315 Views)
