FPGA code successfully compiled in 2010 is giving compilation error in 2014.
I have developed RS485 FPGA code and successfully compiled with LabVIEW FPGA 2010.
Later changed the software to 2014 and installed Xilinx 14.7.
Now if I compile the same code with LabVIEW 2014 compile worker, i am getting error 'Process "Synthesis" failed'.
I am using a case structure with Error cluster as selector, So the case structure has 'No error' and 'Error' cases.
If I change the selector to 'True/False' then the compilation works.
Below is the error that i am getting when using Case structure with Error cluster as selector
 LabVIEW FPGA: The compilation failed due to a Xilinx error. Details: ERROR:HDLParsers:1401 - "C:/NIFPGA/jobs/JyWfWcc_Gv3a9ah/NiFpgaAG_00000041_CaseStructureFrame_0001.vhd" Line 41. Object tunnel_s_error_out_2007 of mode OUT cannot be read. ERROR:HDLParsers:1401 - "C:/NIFPGA/jobs/JyWfWcc_Gv3a9ah/NiFpgaAG_00000041_CaseStructureFrame_0001.vhd" Line 42. Object tunnel_s_error_out_2007 of mode OUT cannot be read. --> Total memory usage is 190240 kilobytes Number of errors : 2 ( 0 filtered) Number of warnings: 1 ( 0 filtered) Number of infos : 0 ( 0 filtered)
(5,028 Views)
Attached FPGA_error_2014.jpg which depicts the working and 'not working' code in 2014.
In 'Not working' code,the selector terminal is error cluster.
I am able to resolve the issue just by changing the selecter terminal to boolean as in 'working code'.
 But both sets of software code works fine in version 2010.
(5,009 Views)
