sbRIO usb camera, driver from myRIO
in myRIO the common USB camera works, is it possible to use the same set of drivers on sbRIO 9636?
I think it has the same OS, USB, only the CPU is different.
I can see the USB device, but not as an IMAQ camera.
Older posts says it was not possible, but there should be new drivers...
Thanks a lot.
Neo
Hardware-designer, inventor, freak...
FEI, VSB Technical University Ostrava
(6,267 Views)
Hi NeoGHOST,
The sbRIO-9636 and myRIO are quite different under the hood.  They use a different processor and OS.  sbRIO-9636 is using VxWorks OS on a Power PC and myRIO uses NI Linux RT on a dual-core ARM processor.
I'm not very familiar with the USB Camera driver, but I wanted to point out that it would diffenately require a different back end implementation to support both targets.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(6,265 Views)
thanks for a fast reply.
I thought there is some major difference between boards,
because it does not work on sbRIO with similar drivers.
It is a pity, because the USB port is on the board already...
Thanks a lot.
Neo
(6,258 Views)
Hi Neo,
Your sbRIO can interface with USB3 Vision cameras that are backwards compatible with USB 2.0, as per this KB: http://digital.ni.com/public.nsf/allkb/F270DE974BF028C486257BF100626B0B. The camera you used on the myRIO is a UVC compliant webcam, and that will not work on the sbRIO which runs the VxWorks RTOS as Spex has mentioned. Take a look at this KB also for some more information: http://www.ni.com/white-paper/13045/en/.
Joseph
(6,248 Views)
