FlexRIO changing sampling rate and length for FFT
Hi all,
I am just trying to take an FFT of a real analog signal into my NI 5781. My code on the FPGA side, adapted from a NI example, basically looks like a single-cycle timed loop with an FFT IP inside. Everything works but I want to be able to change the integration time (sample number) as well as the sampling rate.
Sampling Rate:
I've been changing the sampling rate by deriving clocks from the 40MHz one on my FPGA. Problem is that the minimum is 2.5 MHz.
Integration Time:
I've been setting this by simply choosing the LENGTH my FFT IP works with (either  1024,2048,4096, 8192). LENGTH/SamplingRate = Integration time
It's no surprised that my options for sampling and integration time have been limited.
I would very much appreciate if some could provide me with tips or links to examples that show how I can get different sampling rates and integration times. Perhaps I could lower my sampling rate by a factor of two by writing to buffer only every other loop iteration. Things of that nature would be help.
Thanks!
Jeffrey Lee
(5,104 Views)
There is an example that shows how to use the FFT function in LabVIEW inside a SCTL if your data rate is slower than the loop rate.  The example is called FFT with Handshaking - R Series.  You can find it by going Help >> Find Examples.  Once there navigate to Toolkits and Modules >> FPGA >> FPGA Fundamentlas >> Analysis and Control.
Let us know if that helps!
(5,089 Views)
