09-20-2013 12:05 PM
I am designing a board to directly interface the 9606 via RMC to control our inverter. I want to use Serial, CAN, USB, etc, but the pinout says those pins are reserved. Can someone provide a pinout for the whole RMC connector?
Additionaly, how does one acess those functions via labview? I am also wondering why this information is not directly avaialable up front. One document said these "features may notn be compatable with future RMC host devices." What does this mean?
Thanks!
		09-23-2013
		11:21 AM
 - last edited on
		10-13-2024
		10:29 PM
 by
			Content Cleaner
The pins are listed as reserved because their purpose may be different with future RMC host devices. In order for you to get a full pinout of the RMC connector to gain access to the Serial, CAN, USB, etc features then you need to contact your local Field Engineer to ask about these options. This is listed in the manual under the RMC connector section as well as the linked 'RMC Design for NI Single-Board RIO' presentation (below):
This information is not available up front because of the fact that certain features have not been fully defined and are subject to change in the future. So in order to make sure everything is understood and works properly, we must go through the right channels to ensure this. I understand that this is not ideal for you but I just wanted to relay this information to you.
