Generate CAN frame stream in sbRIO9607
I need to transmit cyclic CAN frames every 100 ms  in sbRIO9607 , since XNET software is not available for single broad RIOs I have to use the basic Embedded CAN  write.vi function and a timed loop to achieve that . When there are multiple frames with different cycles is there any alternative architect that works efficient?
Thanks for the help
(2,475 Views)
Do you run into problems using multiple timed loops for each?
(2,451 Views)
I have tried one frame /one timed loop with no issue , have not tried multi frame/multi timed loop yet . I am trying to find out if there are other ways to do that before committing the code.
(2,445 Views)
