How can I log data to disk from the PCI-7030/6040E Real-Time DAQ board?
Once I have acquired data with a DAQ operation running on the PCI-7030 (or PXI-7030), how can I log that data to my hard drive?
(3,984 Views)
Since the 7030 boards have no hard drive, you cannot perform file I/O with the VI that is running on the 7030. Instead, you should run a second VI on the host concurrently to communicate with the VI on the 7030. Using VI Server, TCP/IP, or shared memory VIs, you can transmit data to the host VI, which can then log the data to the host computer's hard disk (see attached VIs).
(3,982 Views)
It was simple but efficient.
(3,982 Views)
Please help me also.
I'm using pxi 6052E board.I'm acquiring datas through DAq vis.I want to disply them and also store them in file for future print out purposes.I have succeeded in displaying.But i dont know where to start for datalogging and printing them on request.
Thanku
(3,982 Views)
Hi BOB
I tried implementing the same for my application using PCI 7030/6040E but my data is not getting stored. I have posted my VI's and the textfile file under labview, subject : 7030/6040E.
Can you pls help me.
Krithika
(3,738 Views)
