How can I prevent that the ethernet connection between the host and the target abort if a failure on the target occurs?
the network watchdog allways disconnect the target from the host computer if a failiure occurs on the real time target. But I need the ethernet connection. How can I prevent this?
Thank's in advance
(3,093 Views)
hi,
perhaps this link (with sub-links) will help you:
http://zone.ni.com/devzone/conceptd.nsf/webmain/031f97a477ac13e486256b52005c27e2
if not, please write how you configered and what hardware you are using.
(3,085 Views)
