Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I prevent that the ethernet connection between the host and the target abort if a failure on the target occurs?
KN-OP
Member
06-10-2005
03:23 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
the network watchdog allways disconnect the target from the host computer if a failiure occurs on the real time target. But I need the ethernet connection. How can I prevent this?
Thank's in advance
0
Kudos
Message
1
of 2
(3,090 Views)
Reply
Re: How can I prevent that the ethernet connection between the host and the target abort if a failure on the target occurs?
Watermann
NI Employee (retired)
06-13-2005
04:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
hi,
perhaps this link (with sub-links) will help you:
http://zone.ni.com/devzone/conceptd.nsf/webmain/031f97a477ac13e486256b52005c27e2
if not, please write how you configered and what hardware you are using.
0
Kudos
Message
2
of 2
(3,082 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
