How can I save data form cRio 9002?
Hi, guys
I have a NI 9002, NI 9102 and I/O modules and I am testing a FPGA code.
I created a simple project only to get access of the i/o modules. I had done a vi to access the i/o ports and loaded in fpga, after I did this attached code in host to work with the data acquired. The main code runs fine, but when I finish the program and expect it to save some warnings generated by main code in string format, the vi stop but the file is not created in specified path. What is the problem? How can I create a file in host and save the string data into this file?
(5,732 Views)
here is my code and how I mounted my project
(5,731 Views)
Hello!
In your program I saw some mistakes.
In LabVIEW Examples you will found a example call's "Write to Text".
This example is used to  acquisition so you should make some changes.
Good Luck in your application!
Best Regards!
Rita Souza
Engenharia de Aplicações
National Instruments Brazil
(5,715 Views)
