nirviGetModlnfo_cRioStock_res_modGen.vi
We have NI Developer Suite 2010, which included LabView 2009 sp1, with the real time and FPGA modules.  I am working with a sbRIO 9631.  This system and sbRIO worked fine a year ago.
On compiling a small FPGA vi I got this error:
An internal software error has occurred. Please contact National Instruments
technical support at ni.com/support with the following information:
Error 1003 occurred at Module Generator VI Broken: C:\ Program Files\ National lnstruments\ LabVIEW 2009\vi.lib\ LabVIEW Targets\ FPGA\cRIO\ shared\nicrio_StockModGens\ cRioStock_res_modGen.llb\nirviGetModlnfo_cRioStock_res_modGen.vi
Possible reason(s):
Lab VIEW: The VI is not executable. Most likely the VI is broken or one of its [
sub VIs cannot be located. Select File>> Open to open the VI and then verify that
you are able to run it.
If I open this vi the run arrow is broken, It says no VIs are missing.  I can't look at the block diagram (its locked).  So how can I proceed?????
(5,238 Views)
Try repairing the installation of the FPGA Module. To do this you will need your installation media. The repair option is found in the add/remove programs for National Instruments software. It appears that the file has become corrupted on the computer. This is rare but it can happen. If the repair of the FPGA module does not fix the problem, try repairing LabVIEW.
Alex D
Systems Engineer
Academic Research
(5,231 Views)
