05-15-2013 10:41 PM
HI
I want to connect the NI9422 to an Encoder.
The encoder data sheet is :
http://mdm.kpno.noao.edu/td/PDFs/BEI/H25_Incremental_Encoder.pdf
Looking forward to some help on this matter.
Im using cRIO 9024 and My encoder is BEI H25D-SS-512-ABC-7830-LED-EM16-S
Pinouts for encoder are:
A > A
B> B
C> A-
D> +5V
E> B-
F> 0V
G> Case ground.
Thank you.
R.H.
Solved! Go to Solution.
05-16-2013
11:08 PM
- last edited on
03-25-2025
04:01 PM
by
Content Cleaner
hi,
I think you should be using 9411(https://www.ni.com/en-us/shop/model/ni-9411.html) module since that has differential digital input.Looks like you have the wrong module to use. Your incremental encoder has A+, A- and B+, B- which requires differential inputs. 9422 is a 8 channel digital input module for 24V to 60V logic level input, which does not meet your requirements and it is also not differential input.
If you have the correct module, then maybe you can visit this page to find out more?
rando
05-19-2013 09:45 PM - edited 05-19-2013 09:46 PM
Hi
Thank you for the very useful information.
Best Regards
R.
