How i can connect this 8 bit shift register circuit with slide(meter) to control the speed of LED
I'm a newbie to LabVIEW.Currently I'm doing few design peoblems for my assignment.
Actually,i have no idea how to connect it.The slide(meter) funtion is to control the speed of LED in this 8 bit shift register circuit.
Please help me to look at this problem and guide me to the final requirement.
Attached with what I have done.
Thank you.
Best Regards,
Fris...
(4,303 Views)
It would be better if you could post your VI so we can see what you have done. Also, what kind of assignment is it?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,285 Views)
Use build array to merge boolean together.
Then, use boolean array to number.
(4,279 Views)
Actually sir ,I used the old version 7.0 ..
I attached it here.Hope it can help.This is for my assignment for my electronic engineering course...And i and my friend has no idea to make it.Smiley Wink
(4,271 Views)
No matter which version you use.
Just follow the step I told you.
If you don't try it yourself, no one can help you.
If you claim that you're new to LabVIEW, search ni.com with 'labview tutorial' keywords.
(4,265 Views)
