How to configure the outputs voltage of NI 9477
I'm trying to control a motor driver using a cRIO 9074 with the NI 9477 module. I would like to configure the outputs voltage of the module and as I understand, they range between 5 to 60V.
How can I have an output of 24V ?
Thank you.
(6,650 Views)
Hi JaneDoe94,
Thank you for posting.
Here is the specification of your module :
OPERATING INSTRUCTIONS AND SPECIFICATIONS NI 9477
According to page 8 and 9 (see pecture below) you will need an external power supply.
You should have a more detailed picture on the side of your module.
Hope it will help you.
Best Regards,
(6,634 Views)
Thank you Isabelle.
So if I understand correctly, can I use an output as a switch ?
If I choose a pull-up resistor so the current stay under 1A, would this work ?
For example, I'm thinking of using R = 20kOhms and DC = 24V. I need the current to stay below 5mA.
(6,625 Views)
Accepted by JaneDoe94
The 9477 is basically a relay to connect to ground.  But do watch your voltage and current limits.  The maximum current it can sink is 0.625A per line.  So make sure you stay below that.
(6,618 Views)
