How to implement transfer functions for decoupling purpose in labview??
Hello;
I am doing my senior project in controlling extruder machine using LabView. I did my design and simulation using SIMULINK but I need to implement some transfer functions in labview for decoupling the process.
For example:
My input signal should pass through some transfer function and I wanna convert the output into control signal in voltage. How can I do this in LabView.
Regards
Waleed Abdul Ati
(3,929 Views)
Hi Waleed1984,
Let me first ask what you mean by decouple.  And for your output voltage, are you using a DAQ card (and at what speed).
There are a few ways to implement a signal passing through a transfer function and then outputing to a DAQ card.  My favorite at this moment is using MathScript.  I have attached a quick example program of how I would do it.
Brian K.
(3,919 Views)
Hi Mr.Brian K.,
Thank you for your help but can you please send me the file agian using LabView 8 because I don't have version 8.2.
Regarding decoupling, actually I have 2 inter-acting processes and I used multivariable control techniques. So, I used decoupling in which I separate each process from the other and by this way I will be able to design 2 different controllers easily.
In the following article you will find information about decoupling and multivariable control.
Regarding DAQ cards, I am using NI USB-6009.
Thank you
Waleed
Message Edited by Waleed1984 on 02-26-2007 02:43 AM
(3,917 Views)
Please take in consideration that my transfer functions contains time delay equals 90 seconds.
(3,904 Views)
Hi Waleed,
Here is my example in LabVIEW 8.0.   Hope this clears up a way that you can solve this problem.
Brian K.
(3,891 Views)
