How to resolve the conflict resolution of cRIO9022, a very strange problem?
Today I met a very strange question.
When I try to run a simple program, the Labview give me warnning, told me that the software in my target is not right.
Therefore, I checked it in MAX but no software was found in my cRIO 9022.  I tried to reinstall these softares but a warnning I never saw before was showing when initializing.
I have tried to reset it and initialized the IP, but nothing is help. I also checked it in the web and it told me that I need reinstall the software. But the problem is that I cannot. What should I do now? Please give me some help. Thank you very much !!!
(4,769 Views)
Are you connected to the same subnet of the cRIO, the first time you connect the cRIO is necessary to be in the same local network in order to NI-MAX to recognized. You can try to connect the computer to the same subnet and then you can move the computer to other network once you know the IP address.
You can use this document that is going to give all the necessary information:
http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
Randy @Rscd27@
(4,743 Views)
Thank you very much. It is not about the net. Finally, I formated my device and installed all software again, then it works now.
(4,729 Views)
Hello Zayer,
Thats great news!!!
Randy @Rscd27@
(4,714 Views)
