cRIO and heat flux sensors
I was wondering if anyone in the NI Community has had successful experience taking Heat Flux measurements with the cRio hardware? I have a GHT-2C Geothermal heat flux sensor from International Thermal Instruments and I am trying to find a suitable cRio module. The sensitivity of the GHT-2C is 4 Watts/M2, mV (Nom.). I will be taking some ground measurements, so I'm not sure what measurements I will be expecting or getting. I am looking for a module that can give me accurate measurements as well as low noicse/interference. Does anybody have a suitable solution for this application? Thank you.
(4,606 Views)
Hi cdrras1,
I am not sure if anyone has already tiried that particular sensor on a cRIO plattform. I have done a little search on our Community Examples but I was not lucky finding an example that specific, however, depending on the sensor specs, you could consider (like to get a start on the cRIO modules) the 9205, which is an industrial I/O with 16bit of Analog Input resolution. Also I imagine that for your application you should also consider some other things so I would also suggest you to get in contact with some of the sales engineers form National Instruments that help you analyze what would be better for your system.
Sil.VI
(4,578 Views)
